Host Flapping
Jul 5th, 2008
I m getting following error in my L# switch. How to rectify the problem.. which leads my network slow..
%C4K_EBM-4-HOSTFLAPPING: Host 02:01:00:00:00:00 in vlan 1 is flapping between port Gi5/2 and port Gi 4/22
n.nandrekar Sun, 07/06/2008 - 10:09
  • Silver, 250 points or more
Hi!
this could mean that the same host mac address frames are being recieved on both the interfaces, pointing to a probable loop in the network.
niranjan
n.nandrekar Mon, 07/07/2008 - 06:28
what is the topology connected to both the posts? are those 2 ports indirectly connected through hub/switch?
vinothlb1 Mon, 07/07/2008 - 20:18
Both gigabit ports are connected to L3 switch.
Gi/7 connected to my antivirus server. Gi/14 connected to fileserver.. .There is no load balance..
Pravin Phadte Mon, 07/07/2008 - 06:33
Plz let us know what is connected to this switch ports.
also the running confg for both would be helpful.
regards,
pravin
cowetacoit Mon, 07/07/2008 - 09:42
I had a similar problem once. It was a couple servers that had Teamed NIC's. It wasn't configured properly on the broadcom software. If your network is slow it sounds like it could be a network loop.
Pravin Phadte Mon, 07/07/2008 - 09:47
It can also be possible if the servers connected to the switch ports are set for load balancing.
Pravin
