EIGRP--load Balance
Jul 6th, 2008
I am confused in regrading Eigrp load balance. please clear me my confusion.
I have Ho router which connect another BR. from Ho to Br has 3 link. example
E=HO and A=BR
· E-B-A with a metric of 30
· E-C-A with a metric of 20
· E-D-A with a metric of 45
Now my question is>
1. If I run Eigrp then by default equal load balance and with 3 link data is transfer same time to go destination Br? or only data transfer E-C-A ?.
2. If I use variance 2 then EIGRP provide unqual load blance link path
E-B-A and E-C-A.
so my confusion is at first normal eigrp run then 3 link use for data transfer to go destination A and when I want only two link use for data transfer to go destination A same time then I use Variance ?
thanks
biplob
a.alekseev Sun, 07/06/2008 - 01:15
  • Gold, 750 points or more
you can use one link, two links, three liks...
It depends only on your wish.
biplobkhan Sun, 07/06/2008 - 02:17
hi
by default using eigrp one link or all three link use ? how i can use one or two or three link ?
thanks
biplob
a.alekseev Sun, 07/06/2008 - 02:42
use command "variance 2" under EIGRP configuration.
a.alekseev Sun, 07/06/2008 - 03:29
by default eigrp do load balancing between paths with equal cost.
biplobkhan Mon, 07/07/2008 - 02:42
accoring to answer by default eigrp use three path E-C-A, E-B-A, E-D-A ? same time.
to go reach destination from E to A.
Biplob
biplobkhan Mon, 07/07/2008 - 02:46
difference between equal and unequal loadbalance ?
1. if metric is same among the three path then it is called equal load balance ?
2. if metric is not same among the three path then it is called un equal load balance ?
Biplob
