back up and restore DB on ACS v4.2
Jul 6th, 2008
Hi Guys,
I have a ACS v3.0 running and planning to have another one as secondary, here is the question --> how could I restore the ACS's v3.0 DB on the ACS v4.2 !!
Overall Rating: 4 (1 ratings)
Jagdeep Gambhir Mon, 07/07/2008 - 06:04
You need to follow this upgrade path,
During each upgrade it will ask " if you want to keep existing database "..make sure to enable that, else it will remove your existing acs database.
You will need all these software to upgrade it.
Do rate helpful posts
balsheikh Mon, 07/07/2008 - 12:23
Hi JG,
thanks for your comment, maybe i wasn't clear enough on my previous post, actaully I need to backup the ACS's v3.0 database then restore it on another ACS run v4.2 without upgrade the existing one.
is it possible !!
Jagdeep Gambhir Mon, 07/07/2008 - 13:50
You cannot upgrade acs backup config to acs running on different code. You need to install acs 3.0 on new server and then upgrade it step by step.
Better to open a TAC case for this.
