asa<->ios l2l vpn issue - oneway data
creatorizh
Topology
10.23.26.2---\
-------------WAN-asa 5520
10.23.26.198-/
10.23.26.2 has subnet 172.16.16.0/24, asa - 192.168.10.0/24
10.23.26.2#ping ip 192.168.10.212 so 172.16.16.1
Sending 5, 100-byte ICMP Echos to 192.168.10.212, timeout is 2 seconds:
Packet sent with a source address of 172.16.16.1
Success rate is 0 percent (0/5)
But I see both requests and reply on asa
asa# ICMP echo request from outside:172.16.16.1 to inside:192.168.10.212 ID=48 seq=0 len=72
ICMP echo reply from inside:192.168.10.212 to outside:172.16.16.1 ID=48 seq=0 len=72
But when I simply change 10.23.26.2 to 10.23.26.198 in asa - tunnel work succesfully in both directions.
I dont have any ideas, any possible solutions doesn't help: reverse-route, df, tcp adjust-mss.
Please help - where I'm wrong?
7 Replies 7
a.alekseev
Level 7
Level 7
clear crypto isakmp sa
clear crypto ipsec sa
conf t
logg on
logg mon 7 (or logg con 7)
deb crypto ipsec
deb crypto isakmp
thanks for your attention
debug attached
try to ping and
show "sh crypto ipsec sa" on both sides
ok, and "debug crypto engine 127" icluded
looks like all ok with the VPN
are you able to ping 192.168.10.212 from 192.168.10.0/24 network?
yes, and as I wrote in first message icmp reply arrived to asa
#debug icmp trace
Logging of denied packets was enabled, and no any dropped pings at this time (only normal messages about built/teardown connection are logged).
Router doesn't received this reply.
no firewalling on it, checked with "debug ip packets" and "debug crypto engine pack".
I cannot check this now, but it looks like asa sends reply to outside interface w/o tunneling.
When remote peer is 10.23.26.198, routing of the same subnet (172.16.16.0) into tunnel works fine.
internal topology (asa site)
10.23.26.6/30 (outside Gig0/1 asa)-10.10.10.2/30 (inside gig 0/0 asa) <->10.10.10.1/30 (gig eth, cat3560)-192.168.10.212/24 (vlan 1, cat3560)
