sip call overflow
Jul 6th, 2008
I have one AS5400XM, it handles the sip calls and routes the call to providers. The first route is provider A, second is provider B, the last is provider C. I find that the call cannot overflow to provider B and C. any missing?
rgds
The dial-peer setting is
R1
dial-peer voice 6501 voip
description provider A
tone ringback alert-no-PI
service session
destination-pattern 65.
max-conn 108
session protocol sipv2
session target ipv4:192.168.12.32
dtmf-relay rtp-nte h245-signal h245-alphanumeric
dial-peer voice 6502 voip
service session
max-conn 108
session target ipv4:192.168.12.33
dial-peer voice 6503 voip
description provider B
service session
pref 1
max-conn 108
session target ipv4:192.168.24.32
dial-peer voice 6504 voip
service session
pref 1
session target ipv4:192.168.24.33
dial-peer voice 6505 voip
description provider C
service session
pref 2
max-conn 108
session target ipv4:192.168.36.32
dial-peer voice 6506 voip
service session
pref 2
max-conn 108
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Sun, 07/06/2008 - 09:08
Hi, you need "no huntstop" configured for all the DPs.
Also note DP 6504 has no max-conn configured so it won't stop accepting calls there.
anitachoi3 Mon, 07/07/2008 - 07:39
The correct setting should be with "no huntstop". this setting can work in sip call. Does it support h323 call?
rdgs
R1
no huntstop
no huntstop
no huntstop
no huntstop
max-conn 108
no huntstop
no huntstop
Paolo Bevilacqua Mon, 07/07/2008 - 09:37
Yes, most DP settings work the same no matter what the protocol used.
As an appreciation to those providing answers, please rate useful posts!
anitachoi3 Thu, 07/10/2008 - 09:00
If the proivder A sip servers down, does it overflow to the providers B? if so, which timer to control the overflow when first Dial-peer down?
e.g.
1 second, the call will overflow,
or 3 seconds later, the call will overflow
rdgs
anitachoi3 Fri, 07/11/2008 - 17:10
By default setting, the proivder A goes down, does the sip call flow to provider B base on the config?
rdgs
