I cannot hear the music on hold from several phones
Jul 6th, 2008
i have changed the default music on hold that is sample audio, by another, but this last cannot be heared by greater than 2 simultaneously.when i configure back the default music, it can be heared normally.
Note : this music is provided by cisco and stored at the CD that is bought by the Call manager package.
how can i troubleshoot this problem .
gogasca Sun, 07/06/2008 - 15:37
  • Green, 3000 points or more
"but this last cannot be heared by greater than 2 simultaneously"
Could you please clarify this
Verify Audio Source both User and Network are configured properly
Check that MOH file exist under MOH folder in TFTPPath
Check codec configured between MOh and Telephones|Gateway underIPVMS service parameters
Check EVent Viewer...
etc etc..
Upload CCM detailed trace
