backup restore configurations
Jul 6th, 2008
how can i backup the configuration of a switch using Telnet ?
How can i Restore the backed up configuration using the console ?
JORGE RODRIGUEZ Sun, 07/06/2008 - 10:43
Go over this complete link.
Managing software images/working with Configuration files - backup restore
for just console connectivity using terminal emulator try
switch#copy xmodem: ? <-- place question mark to see submenu options
PLS rate any helpful post if it does!
majdalani Sun, 07/06/2008 - 14:29
when i execute the following command :
copy flash:config.text tftp:
i get :
%Error opening tftp:// (Timed out)
about the tftp, should i install a specific software on my machine ? where will the config.text file be stored ?
