C2801 isdn connected?
Jul 6th, 2008
Hi all
How can I check if the isdn NT (Network terminal) is really attached to mi BRI slot.
I use sh isdn status command and layer1 in some Routers is activated but in others is deactivated, but when i check my backup it works fine so the line is attached.(in the deactivated ones)
Thanks in advance
paolo bevilacqua Sun, 07/06/2008 - 12:22
  • Hall of Fame,
    Founding Member
Hi, it is normal that the switch deactivates BRI L1 and L2 after a timeout.
It is then reactivated when a calls is made or received.
