How to see in command line if the SSID is set to broadcast
Jul 6th, 2008
Can someone tell me the command to see from the command line if i have broadcast set up for the SSID
EDIT
I resolved this, I overlooked the guest-mode
amritpatek Fri, 07/11/2008 - 14:23
  • Silver, 250 points or more
You can see in the command sh running-config command
show running-config : Displays the current access point operating configuration
Use the guest-mode SSID configuration mode command to configure the radio interface (for the specified SSID) to support guest mode. Use the no form of the command to disable the guest mode.
[no] guest-mode .
Here is the guideline for usage
The access point can have one guest-mode SSID or none at all. The guest-mode SSID is used in beacon frames and response frames to probe requests that specify the empty or wildcard SSID. If no guest-mode SSID exists, the beacon contains no SSID and probe requests with the wildcard SSID are ignored. Disabling the guest mode makes the networks slightly more secure. Enabling the guest mode helps clients that passively scan (do not transmit) associate with the access point. It also allows clients configured without a SSID to associate.
Examples
This example shows how to set the wireless LAN for the specified SSID into guest mode:
AP(config-if-ssid)# guest-mode
This example shows how to reset the guest-mode parameter to default values:
AP(config-if-ssid)# no guest-mode
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
