Telnet to Switch Issue
kian_hong2000
I have two Switches A and B. Currently, the fibre is connected to only Switch A which is live.
Say now i bring in a new Switch B. I try to trunk the fastethernet to Switch A and it works. I am able to access internet through Switch B.
1) However, i cannot telnet to Switch B. I have already configure a telnet password. What could went wrong?
2) I tried to telnet to Switch A but i could not type in the username and password.
The moment i type in, it will display:
"Username: Connection closed by foreign host."
Why it will affect Switch A connection?
3)Lastly, i choose to connect from fastethernet interface to the other fasterthernet interface. Both are 3560 series switches.
Is it because i did not use a GigaStack module to connect to each other or fasterthernet interface is not allowed to connected to another fasterthernet interface?
6 Replies 6
joseph.derrick
Have you configured a management ip address on switch B ?
Can you telnet to switch A if your host is directly connected to its ports and not through switch B ?
K0rg
Both Switch A and B have a different management IP and are within the same subnet and domain name.
I am able to telnet to Switch A. However, i cannot proceed after i telnet in. All the hosts are connected to Switch A and B and are able to access internet.
This issue is i cannot remotely monitor both the swithes after i add in a new switch B.
Rick Morris
Level 6
Level 6
to make sure I understand.
Switch A
vlan 1 (management)
IP address 10.0.0.1 255.255.255.0 (example only)
Switch B
vlan 1 (management)
IP address 10.0.0.2 255.255.255.0 (example only)
on switch A do a sh cd neigh detail and see if switch A can see switch B
I am able to see Switch A from Switch B.
I think it is a seperate issue. I take out the connection from Switch B to Switch A.
However, Switch A stills get the same error.
User Access Verification
What causes it to be disconnect?
I have found out the root cause.
I have type in the same IP address in Switch B. That is the reason why i telnet to Switch A, it always disconnect itself. It is a human error.
I have tried to connected through fasterthernet interfaces between two switches using cross cable and it works.
