VPN disconnects after 1hr
gandhi.ganesh
My Remote access VPN disconnects after 1 hr when I am doing some work (not idle)
FYI: VPn group idle & session timeout is none
6 Replies 6
srue
Level 7
Level 7
*edit*
nevermind, i see you posed to the other forum also.
pls find the config
5220
Level 4
Level 4
Add the command "re-xauth enable" in each RA group where " re-xauth disable" is currently configured.
Then see if it still disconnects.
Please rate if this helped.
Daniel
This command is used for reauthenicate purpose means if it disconnects only try to reconnect again but my question is y it is disconnecting when i am working not idle below is the link
http://www.cisco.com/en/US/docs/security/asa/asa70/command/reference/mr.html
Can you enable logging on the VPN Client and set it to High on all sections.
Then attach the log captured during the disconnect.
Remember to replace the sensitive info.
Please find the logs & error message
one thing we observed after connecting to vpn & my application server if i open a IE browser it disconnects i think we need to work on this part
