vty access
Jul 6th, 2008
Correct me if I'm wrong, from what I understand the default configuration of "line vty x y" prevents or doesn't allow any type of connection. i.e.
line vty 0 4
line vty 5 15
...as the above has a default configuration of "no login" or no "login authentication".
Overall Rating: 5 (1 ratings)
Haris P Sun, 07/06/2008 - 23:19
Dear Dandy ,
By default it will not allow to login through telnet . It will show as "passwd required ,but not set "
but if you set
line vty 0 15
password class
you will be able to login with password " class" , and it's required to put a "password class" under line vty , or otherwise you can put " aaa new-model" under global config which will make the authentication by using AAA , login with tacacs+ or local , the way you configured .
Normally I'm putting aaa new-mdel under global config and then configuring username , passwd on router which will allow to login using the username passwd configured on router and then with enable secret password i will go to priviledge mode . Other option is to put a privildge level 15 under line vty to go diarectly to previldge mode
