Cisco 4006 temperature alarms
Jul 6th, 2008
Hi, we're seeing occassional temperature alarms on a Catalyst 4006. Does anyone know whether there are multiple sensors fitted on the backplane? ( as is the case with a 6500 ) or whether there is just a single sensor fitted to the supervisor engine? The answer affects the downtime slot and the potential heaps of planning I may need to do! thanks for your responses, Mike
