IP subneting
Jul 6th, 2008
hi, i have a network 10.x.96.160/27 total 30 hosts are there in the network. I want 6 IPS seperately so can i vlsm to get the 6 ip seperately and rest of the IPS i want to use seperately.
Haris P Sun, 07/06/2008 - 23:28
Dear ,
Wubnet your class as given below to make 6 IP's on each class .
10.X.96.160 /29
10.X.96.168 /29
10.X.96.176 /29
10.X.96.184 /29
Haris
goutam_04 Sun, 07/06/2008 - 23:38
I want to divide in 2 networks, one is for 6 ips so i can take 1st one .160/29 and another is for rest. so pls. can you tell me what will be network ip and subnet mask for rest of the ips.
Rick Morris Mon, 07/07/2008 - 06:23
what are you wanting?
You are not very clear in what you are wanting to do.
You want to subnet the block.
This much is understood.
You have a /27 which provides 32 addresses, 30 usable.
How many subnets do you want and how many hosts in each subnet do you want?
According to this last post you want 2 subnets, which by your statement would be a /28
16 addresses each, 14 usable.
Then you mention a /29
So, by what you need you will have more than 2 subnets. You will end up with 3, a /28 and 2 /29's
10.0.0.0/27
10.0.0.0 - .31
10.0.0.1 - .30
/28 255.255.255.240
10.0.0.0 - .15
10.0.0.1 - .14 (usable)
/29 255.255.255.248
10.0.0.16 - .23
10.0.0.17 - .22 (usable)
/29 255.255.255.248
10.0.0.24 - .31
10.0.0.25 - .30 (usable)
Is this what you are talking about?
