what is controller T1 interface
Jul 7th, 2008
Hi all,
i see this on router interface
Interface Status Protocol Description
Fa0/0 up up
Fa0/1 up up
Se2/0 up up
Se2/1 admin down down
Se3/0:0 up up
Lo0 up up
sh controller t1 3/0
T1 3/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
Description: Verizon T1 to Seligman Palo Alto
No alarms detected.
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
Data in current interval (269 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
10 Line Code Violations, 58 Path Code Violations
0 Slip Secs, 3 Fr Loss Secs, 4 Line Err Secs, 0 Degraded Mins
7 Errored Secs, 4 Bursty Err Secs, 3 Severely Err Secs, 75 Unavail Secs
Data in Interval 2:
Data in Interval 9:
Data in Interval 10:
Total Data (last 10 15 minute intervals):
10 Line Code Violations, 58 Path Code Violations,
0 Slip Secs, 3 Fr Loss Secs, 4 Line Err Secs, 0 Degraded Mins,
sh int Se3/0:0
Serial3/0:0 is up, line protocol is up
Hardware is PA-MC-8PRI
Internet address is 10.95.244.13/30
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 4/255, rxload 1/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:00:03, output 00:00:00, output hang never
Last clearing of "show interface" counters 4w1d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 40181
Queueing strategy: weighted fair
Output queue: 0/1000/64/40163 (size/max total/threshold/drops)
Conversations 0/16/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 5000 bits/sec, 6 packets/sec
5 minute output rate 27000 bits/sec, 6 packets/sec
49979303 packets input, 519290582 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 1 giants, 0 throttles
48593 input errors, 2711 CRC, 0 frame, 0 overrun, 0 ignored, 24252 abort
52430870 packets output, 4152546207 bytes, 0 underruns
14 carrier transitions no alarm present
Timeslot(s) Used:1-24, subrate: 64Kb/s, transmit delay is 0 flags
can anyone explain we what is difference in serial3/0:0 interface and controller T1 3/0 interface?????????
or are they same interface???
jgross Mon, 07/07/2008 - 03:10
the controller is the physical interface. A T1 has 24 channels.
The interface se3/0:0 is the first B-Channel out of 24.
Bye
Jo
mahesh18 Mon, 07/07/2008 - 19:42
Hi jgross,
Thanks for reply.
so if we have se0 interface which is this
B-channel?
jgross Tue, 07/08/2008 - 00:15
the controller defines the physical parameters, like framing and lincode, and D-channel Protocol, ... .
After you have specified the contoller you will find a corresponding serial interface in the configuration.
This is the D-Channel of the Interface used to exchange control information.
In Europe we have E1 Controllers, with 30 B-Channels to transfer data at 64kBit/s, and one D-Channel to exchange control information.
So there is not only one B-Channel.
E1 Interfaces have 30-B Channels, T1 have 24 B-Channels.
The D-Channel in Europe is in the middle, so it is numbered interface serial2/0:15.
The B-Channels are numbered starting from 0.
So the status of B-Channel 0 can be displayed with
show interface serial 2/0:0
B-Channel No 1 can be displayed with
show interface serial 2/0:1,
up to
show interface serial 2/0:23, for T1,
or
show interface serial 2/0:30, for E1
Bye
Jo
