List of allocated, free and used DDI's and ext's in Call manager..
Answered Question
Jul 7th, 2008
Is there a way to find out what number range that has been installed on our call manager and a list of free numbers and numbers in use?
If so.. how would I go about obtaining it?
Correct Answer by Jaime Valencia about 8 years 10 months ago
you can only get a list of what you have configured, not sure what you mean "in use"
you can use the route plan report and it will show you what is configured on the server, but CUCM has no idea of whether someone is using it or no.
Also CCM does not differentiates between a DDI and anything else. They're all DNs and that's how CUCM sees them. Unless you have DDI on the description there is no way to tell.
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Kid Dynamite Mon, 07/07/2008 - 01:58
Just to clarify.... it has to contain the following..
DDI's in use
DDI's not in use
Ext in use
Ext not in use
... any help appreciated..
Correct Answer
Jaime Valencia Mon, 07/07/2008 - 08:06
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
Kid Dynamite Tue, 07/15/2008 - 05:26
Ok Thanks Jaime... I thought so but just needed clarification as user is insisting that "there should be some kind of feature present"
