roxanam62 Mon, 07/07/2008 - 09:00
thx Gilles , but i have problem with my router , becouse i cant type any thing when it loads IOS , it stops suddenly
Gilles Dufour Mon, 07/07/2008 - 12:47
  • Cisco Employee,
you can BREAK into rommon.
Then type confreg to set the parameters to boot without reading the config.
If that does not work, you can also try to boot a different image via console and if that doesn't work you will need to replace the hardware.
But this is not the best forum for this kind of issues.
Gilles.
