How to use TCL Script?
Answered Question
Jul 7th, 2008
Hi Experts,
do any one know about TCL Scripting on Cisco Router and Switches.
1)How to use TCL ?
2)Do we need to know any progaming language to writee TCL Script?
Thanks in Advnce
Kiran
Thanks in Advnce
Kiran
Correct Answer by Kevin Dorrell about 8 years 7 months ago
Kiran,
This is the standard book for TCL:
http://www.amazon.com/Practical-Programming-Tcl-Tk-4th/dp/0130385603/ref=pd_bbs_sr_1?ie=UTF8&s=books&qid=1215425366&sr=8-1
There is also this book for beginners:
http://www.amazon.com/Tcl-Tk-Programming-Absolute-Beginner/dp/1598634380/ref=pd_bbs_sr_2?ie=UTF8&s=books&qid=1215425366&sr=8-2
TCL is quite an easy language once you are into it, but it is definitely not a zero-effort solution. You will not be able to use it unless you are prepared to work at it a bit.
Can you program in C or in shell or any other scripting language? That would be a good starting point.
Kevin Dorrell
Luxembourg
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Mon, 07/07/2008 - 02:05
You can buy a book or read on the internet. TCL is a very simple language.
Please rate post if it helps!
Correct Answer
Kevin Dorrell Mon, 07/07/2008 - 02:14
Kiran,
Kevin Dorrell
Luxembourg
n.nandrekar Mon, 07/07/2008 - 06:32
hi!
there is an excellent opensource tutor available for TCL known as "TCL Tutor"
It has a lot of lessons and you can run sample codes in that and practice. It explains well along with examples.
Following is the download link :
http://www.msen.com/~clif/TclTutor.html
Hope this is helpful.
(Please rate if it helps)
Niranjan
