CME/CUE IOS compatibility matrix confusion
Jul 7th, 2008
Have used the following link to ensure that the IOS, CME version and CUE versions are correct.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
This does not seem up to date though, as there are many later versions of IOS 124-11.XW?.bin released and not mentioned in the matrix.
Andy advice regarding compatibility would be appreciated.
N.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 07/07/2008 - 02:36
  • Hall of Fame,
    Founding Member
Hi, the matrix is valid for all the XW releases.
Similarly, a matrix for the XZ release would cover all subsequent version unless otherwise noted.
Please rate post if it helps!
norm.trees Mon, 07/07/2008 - 02:51
Thanks for that, what is the most stable XW to date? Think I will stay with XW so I can use all the existing phone loads etc.
paolo bevilacqua Mon, 07/07/2008 - 02:56
  • Hall of Fame,
    Founding Member
XW8 is the latest and is what should be used unless contrary positive information exist.
