Question on 802.1q trunks and L2TPv3
Jul 7th, 2008
I've got a 3640 router that's connected to a 3550 switch. The trunking is set up as dynamic desirable, and I need to change it to be a dot1q trunk. I'm having a little trouble getting that done. I tried doing a:
switchport mode trunk
and the switch became unreachable. Do I need to add something like:
switchport trunk native vlan 77
Parts of the config are included below...
Thanks!
router
interface FastEthernet0/0
no ip address
no ip redirects
no ip proxy-arp
ip pim sparse-mode
ip route-cache flow
speed 100
full-duplex
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.77.0.1 255.255.0.0
no snmp trap link-status
no cdp enable
interface FastEthernet0/0.77
encapsulation dot1Q 77
no cdp enable
xconnect 192.168.7.1 77 pw-class pw-dynamic
Switch
interface FastEthernet0/48
switchport access vlan 77
switchport mode dynamic desirable
speed 100
duplex full
spanning-tree portfast
interface Vlan77
ip address 10.77.0.10 255.255.0.0
ip default-gateway 10.77.0.1
Edison Ortiz Mon, 07/07/2008 - 04:40
The switch became unreachable because on the router you have Vlan 1 associated to subnet 10.77.0.1 while in the switch you have the SVI on Vlan 77 on that subnet.
You need to remove the IP address under Vlan 77 and apply it under Vlan 1 at the switch.
The reason is working in 'access vlan 77' is because the switch is sending the packets untagged and the router is receiving such packets on its native Vlan (Vlan 1).
HTH,
__
Edison.
Please rate helpful posts
spfister336 Mon, 07/07/2008 - 07:37
But would that work? The 10.77.0.1 subnet is associated with vlan 77 elsewhere.
Edison Ortiz Mon, 07/07/2008 - 07:43
where is 'elsewhere'? I'm only seeing 2 devices.
The router is not listing 10.77.0.0/16 as Vlan 77, it's listing it as Vlan 1.
__
Edison.
spfister336 Mon, 07/07/2008 - 10:30
Sorry... I think I got a little bit confused. Most of our (older ATM-connected) remote sites have a 8500 switch, a 3640 router, plus some number of 2900/3500 series access switches. This particular site I'm dealing with only has one access switch. I thought there were others.
Anyway, I meant that most of the ports on this switch are assigned to vlan 77. It won't be a problem to move the 10.77.0.10 address from vlan 77 to vlan 1? I guess there's no way to do this remotely then?
Having the f0/0.77 interface on the router was a fairly late addition, put in while setting up a L2TPv3 tunnel. I was told that I'd need to take the ip address off the main interface and move it to a subinterface. I couldn't put it on the f0/0.77 interface, so that's when I created f0/0.1
Thanks for your help!
AFAIK - the router will not negotiate a trunk port.
Your router interface config is wrong, change to the below:-
no encapsulation dot1Q 1 native
The router is sending "un-tagged" packets into the switch, but the switch vlan 77 - is tagging them with 77, the switch will ignore them. the router will ignore the replies with the tagged "77" frames. Also change the switch port config to:-
no switchport access vlan 77
speed 100
duplex full
no spanning-tree portfast
HTH.
spfister336 Mon, 07/07/2008 - 07:39
I can try that again, but with FastEthernet0/0.77 using 'encapsulation dot1q 77' also, I think it gave me some sort of error and wouldn't do it. I can try it again and post the error that it gave me.
Edison Ortiz Mon, 07/07/2008 - 07:42
Don't change the router side, change the switch side as I instructed, please.
The IP address in the switch is for management only, changing the Vlan and IP in the router is more disruptive for your network design.
HTH,
__
Edison.
Edison Ortiz Mon, 07/07/2008 - 07:51
Andrew,
It gave him an error because f0/0.77 is also using Vlan 77.
You can't have 2 subinterfaces on the same Vlan.
Your instruction is missing the 'clearing' the dot1q information from f0/0.77 prior applying the changes under f0/0.1
In the same token, I'm in disagreement on making the changes in the router while the solution is a lot simpler by changing the switch's SVI IP address which is only used for management, not routing.
__
Edison.
