CCM 4.3 --- IPCC required
Jul 7th, 2008
Hi all,
I have CCM v 4.3. I am looking in installing IPCC premium version. Which version will be compatible for our version of CCM? I am looking in getting IPCC 4.5, will that be compatible with CCM v 4.3.
Thanks for your help.
Nour
Overall Rating: 5 (3 ratings)
Chris Deren Mon, 07/07/2008 - 05:54
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
For CM 4.3 you require UCCX 6.0, anything else will not work.
HTH, please rate all useful posts!
Chris
BCOLE2007 Mon, 07/07/2008 - 16:48
  • Bronze, 100 points or more
Chris
Are you saying 6.0 UCCX because that is only whats currently available from Cisco?
We have 4.3 CM and 4.1 IPCCx.. One of your Berbee colleagues, Ryan T. was down here a few weeks ago checking out our install, I got the impression 4.3 CM is pretty uncommon.
Blair
Chris Deren Mon, 07/07/2008 - 17:04
  • Hall of Fame,
I stand corrected UCCX 4.1 is compatible with CM 4.3. However if you want to upgrade UCCX, the only newer compatible version is UCCX 6.0.
UCCX 4.5 works only with CM 5.X, and UCCX 5.0 works with CM 5.X/6.X.
CM 4.3 in my expereince is not a widely deployed version is it was released after Appliance based CM (5.X) was already out, so it made no sense to deploy 4.3, especially now that Windows based CM has completely been scretched from the roadmap.
I myself have not even worked with 4.3, which is the first CM version since CM 3.1 days I have not touched :-)
Chris
mnour401917_2 Mon, 07/07/2008 - 20:35
Thanks both of you.
that helped me to decide whitch one to go for.
BCOLE2007 Tue, 09/16/2008 - 04:44
Call Manager 4.3 is compatible with IPCCx 4.1
We are currently running it fine and it has been verified as well.
Are you having difficulty with them?
Blair
*Please rate all useful posts.
BCOLE2007 Wed, 09/17/2008 - 04:26
hehehe
I stand corrected, I had mine mixed up
We are running in production
Call Manager 4.1(CCM) and CRS 4.3(IPCC)
thanks for the Matrix link
Blair
*Please rate useful posts*
Chris Deren Wed, 09/17/2008 - 04:53
  • Hall of Fame,
I think you may have these flipped as there is no IPCC 4.3, or you ment to say 4.0.3.
Chris
