Cisco ISR 871 and VOIP
Jul 7th, 2008
Hi I have an 871 that has the following config. The phone connected behind the VLAN 174 will not communicate with the Cisco Call manager. IS there anything I need to do to have the phone communicate with Call manager? The VPN works fine.
Tory#sh run
Building configuration...
Current configuration : 6182 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Tory
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
no aaa new-model
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3758255453
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3758255453
revocation-check none
rsakeypair TP-self-signed-3758255453
dot11 syslog
dot11 ssid toryblaha
authentication open
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.46.1
ip dhcp excluded-address 156.33.174.1
ip dhcp pool sdm-pool1
import all
network 10.10.46.0 255.255.255.0
dns-server 192.168.46.1
default-router 10.10.46.1
ip dhcp pool 174NET
import all
network 156.33.174.0 255.255.255.248
dns-server 156.33.250.10
default-router 156.33.174.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip bootp server
ip domain name yourdomain.com
ip name-server 192.168.46.1
crypto ipsec client ezvpn SDM_EZVPN_CLIENT_1
connect auto
group xxxxx key xxxxx
mode network-extension
peer 156.33.195.51
virtual-interface 1
xauth userid mode http-intercept
archive
log config
hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
bridge irb
interface FastEthernet0
interface FastEthernet1
switchport access vlan 174
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Virtual-Template1 type tunnel
no ip address
tunnel mode ipsec ipv4
interface Dot11Radio0
no ip address
ssid toryblaha
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface Vlan174
ip address 156.33.174.1 255.255.255.248
crypto ipsec client ezvpn SDM_EZVPN_CLIENT_1 inside
interface BVI1
description $ES_LAN$
ip address 10.10.46.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.46.0 0.0.0.255
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner exec ^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
paolo bevilacqua Mon, 07/07/2008 - 05:40
  • Hall of Fame,
    Founding Member
Hi, from the CM, can you ping the phone and viceversa ?
If you're not able to do that, the VPN is not set properly, or you have other routing problems.
Brandon Buffin Mon, 07/07/2008 - 05:41
  • Purple, 4500 points or more
Unless you have it configured manually on the phone, you will need to configure a TFTP server address in the DHCP pool, such as:
option 150 ip 1.1.1.1
Hope this helps. If so, please rate the post.
Brandon
