Etherswitch question
Answered Question
Jul 7th, 2008
  • Bronze, 100 points or more
I noticed cisco says that if 2 etherswitches are in the same router chassis that they must be stacked.
so is the NM-1GE considered an etherswitch?
I was planning on putting both the NM-1GE and NME-16ES-1G in the same router would this require stacking (thus making the NM-1GE useless) or is this a valid setup?
Correct Answer by paolo bevilacqua about 8 years 9 months ago
No, the NM-1GE is not, and is not considered, an etherswitch.
Note that depending on the router where you're placing it, the routing performances for NM-1GE can be much, much less than wire rate.
Please rate post if it helps!
Overall Rating: 5 (3 ratings)
Correct Answer
paolo bevilacqua Mon, 07/07/2008 - 05:52
  • Hall of Fame,
    Founding Member
is66rlhntadm Mon, 07/07/2008 - 06:02
Thanks thats what I thought but I wanted to be sure
I'm planning to put it in a 3745
