Warning message
eigrp feasible successor
Jul 7th, 2008
hi,
I just want to know if this how eigrp show a feasible successor
for exemple:
P 192.168.1.4/30, 1 successors, FD is 29468416
via 192.168.1.18 (29468416/21845248),Serial1/1
via 192.168.1.9 (57912832/21845248), Serial1/0
is the route via 192.168.1.9 is a FS?
thanx
The route via 192.168.1.18 is the first feasible sucessor, the route via 192.168.1.9 is the other.
An example from one of my routers is:-
P x.x.x.x/8, 1 successors, FD is 129767680
via x.x.x.x (129767680/129765120), FastEthernet0/0.2
via x.x.x.x(385250304/128025344), Tunnel3
via x.x.x.x(641250560/128025600), Tunnel4
HTH.
fd_case17 Mon, 07/07/2008 - 06:44
show ip route says: ( in my exemple)
that the route to 192.168.1.0 is via 192.168.1.18 with metric 29468416
so
there is a successor
and a FS :via 192.168.1.9 (57912832/21845248), Serial1/0
its all right
do you know how to change the K values?
Correct.
You change the K values in the EIGRP process. the default K values used are bandwidth and Delay. The command is:-
metric weights tos k1 k2 k3 k4 k5
The command defaults to a setting of 0 1 0 1 0 0, meaning that only bandwidth and delay are used to calculate the metric
HTH.
