Cisco IP Phone 7970 reset messed everything up???
Answered Question
Jul 7th, 2008
I needed to reset a 7970 ip phone to factory defaults and I did the whole hold down # when you start up the phone and then press 123456789*0# thing and it started to reset but it keeps on doing it and won't stop. I have left it on for over 3 days now and its still flashing green on the lights on the right of the sceeen and now nothing it even coming up on the screen. I've tired everything i can think of and i checked everything that i can thinking (DHCP,tftp...) and I got nothing. Please tell me this phone isn't a big expensive paper holder now. All i did was try reset the stupid thing and now I can't and even get it to turn on. Please help!!
Correct Answer by paolo bevilacqua about 8 years 11 months ago
Hi, the easier way is to use one of these little switches with straight cable.
On tftpd32 configure the DHCP tab with option 150 to the IP address of the PC, and a valid pool.
That's all what is required, phone will be the looking for term41.default.loads, you need this file as well the other individual FW files.
Please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 07/07/2008 - 06:57
  • Hall of Fame,
    Founding Member
this is always due to the firmware files not available for one reason or another, on the tftp server.
You could recover the phone connecting it directly on a PC that has tftpd32 (free download) installed and the firmware files.
sgfjacobs Mon, 07/07/2008 - 08:35
p.bevilacqua you have been a lifesaver!!
Now what I connect it though a cross over cable correct? and does it matter what the ip address is of the server, like is it going to look for a default tftp server?
Correct Answer
paolo bevilacqua Mon, 07/07/2008 - 08:42
  • Hall of Fame,
    Founding Member
sgfjacobs Mon, 07/07/2008 - 10:13
I tired it but in the log it kept on saying client requesting ip 192.168.0.100 but is unable to ......
and nothing was happening
I made the starting ip address 192.168.0.99 but still wouldn't take in. Any suggestions??
paolo bevilacqua Mon, 07/07/2008 - 11:02
  • Hall of Fame,
    Founding Member
Make sure you filled the DHCP option field with 150 and the IP of the PC.
The phone doesn't accept the address without that. If 150 doesn't work, try 66.
sgfjacobs Mon, 07/07/2008 - 11:58
Thanks a lot p.bevilacqua. I just had to fool around with it a little and got it working. Now my 7970 is working great!! Thank a lot :)
paolo bevilacqua Mon, 07/07/2008 - 12:19
  • Hall of Fame,
    Founding Member
You summed up the right approach perfectly.
Thanks for the appreciation and good luck!
