CSM HTTP Return Code Checking
Jul 7th, 2008
I am having troubles with a HTTP return code probe I am trying to create. (see config below). I have a vserver built that allows connections to any TCP port, I cannot get a HTTP return code probe to work.
I have tried the following three scenerios:
1. When the vserver is set to allow any TCP port, I can run the command "show mod csm 2 probe name SERVERASP3 detail" and the output looks like this:
NCWS1SWC2A#sh mod csm 2 probe name SERVERASP3 det
probe type port interval retries failed open receive
SERVERASP3 http 5 2 30 10 5
Probe Request: GET /server.asp
Expected Status Codes:
real vserver serverfarm policy status
------------------------------------------------------------------------------ JRRRTST JRRRTST (default) ???
2. When I change the vserver to only allow connections to "www", then the probe works fine....(status shows operational).
3. When I change the vserver to allow connections to HTTPS, the real goes to a PROBE_FAILED state.
Our users hit this vserver using both HTTP and HTTPS, so I am not sure how/if I can get this to work.
serverfarm JRRRTST
nat server
no nat client
predictor leastconns
real <real-IP-address>
vserver JRRRTST
virtual <virtual-address> tcp 0
vlan 246
serverfarm JRRRTST
replicate csrp sticky
replicate csrp connection
persistent rebalance
probe SERVERASP3 http
request method get url /server.asp
expect status 200
interval 5
retries 2
failed 30
receive 5
Gilles Dufour Mon, 07/07/2008 - 07:49
It's because you did not specify any port in the vserver or serverfarm.
So the CSM doesn't know where to see the probe.
Use the port command inside the probe setup.
Also, you should really split your vserver per port - one for http, one for https,....
jrichterkessing Mon, 07/07/2008 - 09:00
Thanks Gilles...that worked, I knew it was something simple I just didn't see it. I agree with you about specifying the port, we are going to run this way for a period of time and narrow it later based on FW access from our private network.
Thanks again...JEff
