7970 Settings button
Jul 7th, 2008
Good Afternoon,
Can someone please help / advise:
Every time i press the settings button on a 7970 handset an error message on screen displays "This key is not active here!".
Please can you advise why this is happening and a possible resolution
Thank you.
Rob Huffman Mon, 07/07/2008 - 06:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chijioke,
Can you check via ccmadmin;
Device>Phone (find this 7970) Product Specific Configuration>Settings Access>Enabled
Hope this helps!
Rob
cetciscocm Mon, 07/07/2008 - 06:57
Cheers Rob,
You are spot on. Configuration was set to disabled. Is this the default setting when adding a device to CCM?
Thanks again
Rob Huffman Mon, 07/07/2008 - 07:20
  • Hall of Fame,
    Founding Member
Hi Chijioke,
Good stuff :) The Default setting when adding IP Phones is "Enabled".
Hope this helps!
Rob
