DR Examples
Jul 7th, 2008
I am working on my first Disaster Recovery project and am having trouble with the concept of the whole thing.. Does anyone know where I can find some examples of Disaster Recovery models using NAT at the DR site?
Thanks in advance,
Don
dcawood33 Mon, 07/07/2008 - 13:31
Thanks for the response. This doc as some good information.
This DR will not be a permenant DR but rather a test. I wil need to stand up a network that is exactly like the current network without interrupting the current traffic at the permanent data center.
To do this there will be a .test url for the new servers. The servers on the DR will have the same ips and NAT will be used to staticaly assign to those ips.. at least that is the plan. I am just not sure how that Nating will actually work and how to ensure traffic at the permanent data center will not be affected.
Have you seen and info on these types of scenarios...
Don
