ASDM Real-Time Log "Filter By:" not Working.
Jul 7th, 2008
I recently upgraded my PIX 535 to v7.2(4) and ASDM to v5.2(4)50 because of a reported vulnerability with the version I was running, well now when I view the real-time logging on the PIX I cannot use the Filtering option. Has anyone else run into this?
hadbou Mon, 07/14/2008 - 11:47
The Logging Filters pane lets you apply message filters to a log destination. Filters applied to a log destination select the messages that are sent to that destination. You can filter messages according to message class and severity level, or use an event list that you can create on the Event Lists pane.
Xxstatikk Thu, 07/17/2008 - 05:12
This doesn't exactly pertain, but I have a ASA 5510 v8.05 with ASDM 6.0(2) and real time log viewer "Filter By" works occasionally and quits working just as much I have to pause and unpause sometimes that works but ASDM is buggy.
