Topology Services issue - LAN Edge view renames gone, VTP view missing APs
Joe Clarke Mon, 07/07/2008 - 08:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The problem with APs is bug, CSCso94546. A patch is available through the TAC. This has been an issue with LMS 3.0 in general. If you are just noticing this, I assume you recently upgraded from LMS 2.6? I have never seen an issue with nested switch clouds, but switch clouds could be "reverting" if the underlying device IDs changed. An upgrade may account for this.
Joe Clarke Mon, 07/07/2008 - 09:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you applied any service packs after applying the patch, that may have overwritten the patched files.
Joe Clarke Mon, 07/07/2008 - 09:56
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Verify that the installed NMSROOT/campus/lib/classpath/com/cisco/nm/ani/server/topo/ComputeRBMap$CdpWalkTopoGroup.class and ComputeRBMap.class match the ones provided to you in the patch. The patch will not stop working on its own.
That said, there was a bug in CM 5.0.2 which could cause Data Collection not to work properly. Upgrading to Campus 5.0.3 will fix it, and it will not overwrite these patched files.
I verified the patches are in the location specified and also compared the md5 hash from the original files I received to the files on the server:
ComputeRBMap$CdpWalkTopoGroup.class MD5 Hash: a60015b10d9e6d89dc94a2a1a80f9252
ComputeRBMap.class MD5 Hash: 2957f81f33bf3fb142fff393d885738e
I'll try the CM patch next i guess.
sb
