RSVP over unnumbered links, ISIS network
wplaice
I am running an unnumbered core with ISIS, ldp is running fine, if i build a TE tunnel it will not establish, i get " Last Error: RSVP:: Could not add RSVP Path: Operation failed: internal error "
if i give my interfaces real addresses then the tunnels establish ok.
is this a limitation of RSVP, or is there a way to run unnumbered links in the core, and still do TE ?
I can't see anything that says it can't be done !
many thanks, Will
Harold Ritter
William,
RSVP TE on ununmbered interfaces is not supported by IOS.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
didyap
Level 6
Level 6
For the configuration for the RSVP follow the URL which will help you :
http://www.cisco.com/en/US/customer/docs/ios/12_1/qos/configuration/guide/qcdrsvp.html
cool, i'm reading through thatm but, i still don't see any reference to unnumbered interfaces... are these allowed ?
Harold Ritter
William,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
