Candidate ID question
Jul 7th, 2008
Is the Candidate ID the same as your VUE ID on the Certification Tracker website? I've been trying to find out how I can find my Candidate ID.
Wilson Samuel Mon, 07/07/2008 - 10:17
If you are talking about the CSCO number then yes.
VUE maintains the respective clients (e.g. Microsoft's MCP Number and Cisco's CSCO No.) for candidate identification unlike the Prometric which uses SP ID for all candidates irrespective of the testing client.
Hope this helps,
Kind Regards,
Wilson Samuel
Chris Deren Mon, 07/07/2008 - 17:15
With Prometric that was the case, I am assuming it would be the same with VUE.
Chris
