Multiple Login's using same user ID
Jul 7th, 2008
I have a Cisco Secure ACS server using which i Authenticate Remote Access VPN Clients,
The problem is users can login multiple times simultaneously using the same Login ID, there is a option for selecting the concurrent sessions, but changing it to '1' didn't help.
Could someone tell if i made a mistake. anywhere.
Jagdeep Gambhir Mon, 07/07/2008 - 09:45
  • Red, 2250 points or more
To make use of that feature, you need to set up radius accounting (start/stop). That will let acs know who is connected at present.
~JG
Do rate helpful posts.
vj_vignesh Mon, 07/07/2008 - 18:46
thanku for the reply, i'll try it soemtime today and update the result.
vj_vignesh Thu, 07/10/2008 - 05:51
Enabling radius accounting also didn't work, but after doing some research, i found another option specifically for Radius(VPn) where i could set teh number of simultaneous login.
Thankyou anyway.
