pix 525 logging
aruiz05
I have a unique problem. I lock myself out of the pix on any interface via ssh,telnet etc . I'm trying to connect directly but logging console is enable and the amount of logs makes it impossible to do anything. any ideas on how to stop it other than reload or disconnecting the interfaces.
nomair_83
Level 3
Level 3
just try to hit no logging enable .it will accept the command...
JORGE RODRIGUEZ
Level 10
Level 10
as the messages scrolls in the screen you can still login just type your user credentials ignoring the messages, go into enable and config mode and type " no logging console"
once you loggin you can create a short script
copy as paste.
config t
no logging console
or if you have access to asdm you can disable logging console from there as well.
Jorge Rodriguez
