7912 transfer pb
Jul 7th, 2008
hi all,
i use UC520 for my plateform, i'm trying tp test its features, i test call transfer in 7940 it work fine but with 7912, it doesn't i want to if that phone doesn't support this features or it's a none good configuration from my part
thinx
paolo bevilacqua Mon, 07/07/2008 - 10:22
  • Hall of Fame,
    Founding Member
Transfer should work the same. What exactly is the problem ?
m.elmaaroufi Tue, 07/08/2008 - 00:34
the problem is when i call the 7912 and i try to transfer the call from this phone to another the call hangup, but when i do this with 7940 it work fine
paolo bevilacqua Tue, 07/08/2008 - 01:29
  • Hall of Fame,
    Founding Member
Which exact IOS (first line of "show ver") and phone FW, check settings, device status, are you using ?
m.elmaaroufi Tue, 07/08/2008 - 23:43
hi,
i'm using:
UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(11)XW7, RELEASE SOFTWARE (fc2)
CME-Phone-Loads-4.2.7 for ccme
