Crazy NAT question
Answered Question
Jul 7th, 2008
Here is what I am trying to do ....
I have a series of hosts A - F. I need them to communicate with hosts in an external/24 network, Network z. The communication can come from any of my hosts to any host in network z. I need to nat the traffic as it leaves my network towards network z but only from the hosts A - F. Also, I need to have static assignments for the NATs of hosts A - F. To make it better in another segment I have hosts G - k that I need to do the same NATting to Network Z but not between each other or any other host on my network.
I would like to not setup 6 nat pools, 6 ip nat inside source list statements and 6 access-lists. Is there a cleaner way of doing this with maybe a route-map or something. I feel that this is much easier than I think I might be making it.
Peper
Correct Answer by a.alekseev about 8 years 10 months ago
conf t
ip access-list ext POLICY-NAT
permit host a.a.a.a z.z.z.0 0.0.0.255
permit host f.f.f.f z.z.z.0 0.0.0.255
route-map POLICY-NAT permit 10
match ip address POLICY-NAT
int f0/0
ip nat outside
int f0/1
ip nat inside
ip nat inside source static a.a.a.a y.y.y.1 route-map POLICY-NAT
ip nat inside source static f.f.f.f y.y.y.6 route-map POLICY-NAT
Overall Rating: 5 (1 ratings)
cybrsage Mon, 07/07/2008 - 10:47
What device are you using to NAT through and what IOS revision?
I do not know the answer to your question, but I can see this as being needed info for others.
peperg Mon, 07/07/2008 - 10:50
varying routers; 2821, 2851, 3845, 6509 (native). All are running 12.4 of one sort or another.
Peper
peperg Mon, 07/07/2008 - 11:31
Peper
Correct Answer
a.alekseev Mon, 07/07/2008 - 11:31
  • Gold, 750 points or more
conf t
int f0/0
ip nat outside
int f0/1
ip nat inside
peperg Mon, 07/07/2008 - 11:49
Thank you!! I just found a doc that describes that pretty closely back in the 12.2 documentation.
I just got handed a snag in that the network Z will also be initiating traffic. Can I add to the same POLICY-NAT acl
permit z.z.z.0 0.0.0.255 host f.f.f.f
From what I can tell it should be able to work both ways.
a.alekseev Mon, 07/07/2008 - 11:58
I think, you needn't
That is enough for bidirectional communication.
