office through PIX515E to remote PPTP VPN
Jul 7th, 2008
I have a PIX515E which used to allow me to successfully connect to a client's VPN using Windows XP PPTP. I'm connecting successfully but the login/password stage is hanging. I've spent a couple of days on the issue and implemented various ideas including
conduit permit gre any any
conduit permit tcp host [ip] eq 1723
static(dmz,outside) [outsideIP] [dmzIP] netmask 255.255.255.255 0 0
Also I've added:
fixup protocol pptp 1723
although I've read that my version of the firmware (6.3(1)) has a bug which was fixed in a subsequent upgrade.
tnx for any advice
singhsaju Wed, 07/09/2008 - 11:55
you mentioned that it used to allow successfully connect. So was this working before ? Also i want to confirm that this is a Pix passthrough scenario.
Check PPTP server logs .
DrSteveBrown Wed, 07/09/2008 - 12:36
Customer owns PPTP server and unable to rapidly help me dx problem. Yes, PIX passthrough I think (outside IP mapped to inside IP) and I also added conduit statements yesterday for good measure.
I ended up connecting successfully through my 515E both via MacOS X and an XP Pro partition on the same computer and same IP address that couldn't connect via XP home. Rather than diagnose the issue with XP/home - and I've disabled firewall, created new VPN connection configs, etc. - I'll just work within XP/Pro.
However it may be interesting for me to search XP tech forums for any issues on PPTP for home version.
DrSteveBrown Wed, 07/09/2008 - 12:41
singhsaju:
one other question: Perhaps I didn't set something up completely. Could you define what you're asking about this being a PIX passthrough scenario ? I had assumed that the config I noted in my post would indicate that there's a passthrough going on but since you're asking the question, then you're welcome to assume that I didn't do everything needed to make this a passthrough scenario.
Just to re-state: I'm trying to get a machine inside my company network to connect through my 515E to the Internet, to a customer's VPN which appears to be an Windows NT-type PPTP machine.
