ssh and http not working after vpn
Jul 7th, 2008
ciscoasa(config)# sh run
: Saved
ASA Version 8.0(2)
hostname ciscoasa
enable password xxx
names
interface Ethernet0/0
nameif outside
security-level 0
ip address ext_ip 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.x.x.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
clock timezone mst -6
access-list split_tunnel_list standard permit 172.17.193.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.17.193.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list admin_access_thru_vpn extended permit ip 192.168.10.0 255.255.255.0 host 172.17.193.1
pager lines 24
logging enable
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
ip local pool vpnuserspool 192.168.10.101-192.168.10.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 172.17.193.0 255.255.255.0
access-group admin_access_thru_vpn in interface outside
route outside 0.0.0.0 0.0.0.0 gw_ip 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.10.0 255.255.255.0 inside
http 172.17.193.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set FirstSet esp-3des esp-md5-hmac
crypto dynamic-map dyn1 1 set transform-set FirstSet
crypto dynamic-map dyn1 1 set reverse-route
crypto map mymap 1 ipsec-isakmp dynamic dyn1
crypto map mymap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
telnet timeout 5
ssh 172.17.193.0 255.255.255.0 inside
ssh 192.168.10.0 255.255.255.0 inside
ssh timeout 60
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
dhcpd address 172.17.193.101-172.17.193.254 inside
dhcpd dns dns_ip_1 dns_ip_2 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
support.edm Mon, 07/07/2008 - 12:17
service-policy global_policy global
ntp server 67.212.67.78 source outside
group-policy vpnuserspolicy internal
group-policy vpnuserspolicy attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel_list
address-pools value vpnuserspool
username admin password xxx encrypted privilege 15
username admin attributes
vpn-group-policy vpnuserspolicy
tunnel-group vpnusersgroup type remote-access
tunnel-group vpnusersgroup ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:xxx
: end
ciscoasa(config)#
support.edm Mon, 07/07/2008 - 12:19
After VPNing in, I want to be able to access the inside interface of ASA using ASDM and SSH. I did the following:
ciscoasa(config)# access-list admin_access_thru_vpn extended permit ip 192.168.10.0 255.255.255.0 host 172.17.193.1
ciscoasa(config)# access-group admin_access_thru_vpn in interface outside
ciscoasa(config)# http 192.168.10.0 255.255.255.0 inside
ciscoasa(config)# ssh 192.168.10.0 255.255.255.0 inside
Getting the below when trying to SSH or ASDM to 172.17.193.1:
3 Jul 07 2008 14:18:24 710003 192.168.10.101 172.17.193.1 TCP access denied by ACL from 192.168.10.101/1666 to outside:172.17.193.1/22
3 Jul 07 2008 14:18:58 710003 192.168.10.101 172.17.193.1 TCP access denied by ACL from 192.168.10.101/1667 to outside:172.17.193.1/443
Any ideas?
a.alekseev Mon, 07/07/2008 - 14:20
  • Gold, 750 points or more
try this
ciscoasa(config)# http 192.168.10.0 255.255.255.0 outside
ciscoasa(config)# ssh 192.168.10.0 255.255.255.0 outside
srue Mon, 07/07/2008 - 18:49
  • Blue, 1500 points or more
try adding the command:
management access inside
