Problem with FXO card
Jul 7th, 2008
Hi, i have a CCM 6 and Unity Connection 2.0 with IVR,all work fine, but i try to connect the lines of the old PBX to FXO card, but when i try to call the line ringing but dont send to IVR.
This is part of the configuration
voice-port 0/2/2
timeouts call-disconnect 2
connection plar opx 3022
description Linea 3265323
caller-id enable
This gateway is configured in H323
Thanks regards,
Carlos
Jaime Valencia Mon, 07/07/2008 - 12:43
  • Cisco Employee,
  • Hall of Fame,
    2011
do you already have a dial peer for 3022 and that DN configured in CUCM to go to VM??
javalenc
if this helps, please rate
cvicentep Mon, 07/07/2008 - 12:55
The configuration of dial-peer is :
dial-peer voice 550 voip
destination-pattern *32T
session target ipv4:172.16.4.1
incoming called-number ....
dtmf-relay h245-alphanumeric
codec g711alaw
ip qos dscp cs5 media
Jaime Valencia Mon, 07/07/2008 - 13:11
  • Cisco Employee,
  • Hall of Fame,
    2011
does it work if you change it to?:
destination-pattern 32..
javalenc
cvicentep Mon, 07/07/2008 - 13:25
i change taht and nothing.
but i execute this comand :
GW#sh voice port 0/2/2
Foreign Exchange Office 0/2/2 Slot is 0, Sub-unit is 2, Port is 2
Type of VoicePort is FXO
Operation State is DOWN
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is Linea 3265323
and appear that.
Jaime Valencia Mon, 07/07/2008 - 14:36
  • Cisco Employee,
  • Hall of Fame,
    2011
then go to voice port config and do a shut / no shut
javalenc
