Presence 6.x configuration
Jul 7th, 2008
All, I hate to be a bonehead on this, but Im having somewhat of a hard time with the Presence configuration. I have this installed, but not really sure where to go or what needs to be done in the configuration. Anyone with any experience in this have a "checklist" of what should be done that they would share? Id appreciate the help.
Overall Rating: 4 (1 ratings)
jjoseph01 Mon, 07/07/2008 - 15:09
Thanks, I found the deployment guide. This should help alot. Thanks again.
gogasca Mon, 07/07/2008 - 15:17
No problem, if you have any issues, please continue posting here
kherzog Wed, 07/09/2008 - 08:05
As a side note, the guide will lead you to setup the application > Cisco Unified Personal Communicator > Settings. What TFTP ip address is suppose to be entered here? I don't see TFTP as a service active in the control panel of the CUPS.
bigcappa1 Wed, 07/09/2008 - 14:08
Once the Presence is up it has an installtion check list you can run through that should help you complete the install. Check the Presence Admin
