Jaime Valencia Mon, 07/07/2008 - 16:12
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM? CME? version?
only happens with CIPC?
internal phone? PSTN phone?
SW or HW CFB?
G711 or G729?
javalenc
if this helps, please rate
rcrumm_2 Mon, 07/07/2008 - 16:25
It turns out the problem is, codec negotiation.
In IPC, configuring the "optimize for low bandwidth" causes codec issues. Since this was local calls there was an issue.
Randall
Jaime Valencia Mon, 07/07/2008 - 16:27
  • Cisco Employee,
  • Hall of Fame,
    2011
that option would cause the call to be established with G729 so if you're using SW CFB that would fail due to the fact it can only handle G711
javalenc
rcrumm_2 Mon, 07/07/2008 - 16:29
correct. Once I changed it... it worked.
Thanks for your help on this and in the past.
Randall
Jaime Valencia Mon, 07/07/2008 - 16:44
  • Cisco Employee,
  • Hall of Fame,
    2011
you're very welcome Randall =)
javalenc
