Identifying if router is a hub or spoke
Jul 7th, 2008
I was wondering if there is something in the VPN Mibs ( or elsewhere ) that will let me figure out if a particular device is acting as a HUB, spoke or full mesh device for a given VPN. I tried using the Route target type - Import/Export/both, but it didn't seem to help in the MIB I was looking at
If I knew that a router was acting as a hub, I could then probably find the spokes for it, but I haven't figured out how to do that yet.
Thanks, Pat
a.alekseev Wed, 07/09/2008 - 00:57
There are no mibs, that can let you to figure out if a particular device is acting as a HUB, spoke or full mesh device for a given VPN.
Farrukh Haroon Wed, 07/09/2008 - 10:36
If this is a DMVPN, try looking at any NHRP related mibs (if any exist).
Farrukh
tapdevdem Wed, 07/09/2008 - 11:04
Thanks for the replies. I read that when configuring Hub and Spoke, the Hub routers are generally in one VPN, and the Spokes are in another. Is this always the case or could they ever be in the same VPN?
tapdevdem Wed, 07/09/2008 - 12:42
I cut and pasted out of a Cisco doc and added it below. Maybe different VPNS was the wrong wording.
Actually, I'm trying to find out for a client connected via a VPN, which routers act as Hubs and Spokes. The doc actually says that the Hubs and Spokes have different VRFs (an upstream and a downstream), not VPNs.
I want to look at the MIBs for the VRfs to see
if I can figure out whether the path is actually going to be full-mesh or hub and spoke. I then want to be able to see for a given VPN, the Hub/Spoke relationships.
I.E. Find which are the hubs and which spokes go through which hubs. Thus if a Hub goes down, I'll know certain Spokes are now unreachable.
Here is output from the doc:
Table 1 Feature Information for Configuring Scalable Hub-and-Spoke MPLS VPNs
Feature Name Releases Feature Configuration Information
MPLS VPN: Half Duplex VRF Support 12.3(6)
12.3(11)T
This feature ensures that VPN clients that connect to the
same PE router at the edge of the MPLS VPN use the hub
site to communicate.
The following sections provide information about this
feature:
• Overview, page 2
• Upstream and Downstream VRFs, page 3
• Reverse Path Forwarding Check, page 3
• How to Ensure that MPLS VPN Clients Use the Hub PE
Router, page 4
CCSP,
