Warning message
Oer with firewall
Jul 7th, 2008
Dear all expert, i has configure a 2811 router for running OER suscessfull without firewall, but once i put in firewall command, when i open http, some time can some time cannot, can anyone see the problem from below show run? (because of line too long, some command i already erase it from here)
ip inspect max-incomplete low 500
ip inspect max-incomplete high 500
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
ip inspect name SDM_LOW isakmp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW ssh
ip inspect name SDM_LOW telnet
ip sla monitor 1
type echo protocol ipIcmpEcho 202.188.0.133 source-interface FastEthernet0/0
timeout 2000
threshold 2
frequency 15
ip sla monitor schedule 1 life forever start-time now
ip sla monitor 2
type echo protocol ipIcmpEcho 202.188.0.133 source-interface FastEthernet0/1
timeout 2000
threshold 2
frequency 15
ip sla monitor schedule 2 life forever start-time now
login on-failure log every 3
login on-success log
oer master
policy-rules OER
port 4444
max-range-utilization percent 10
traceroute probe-delay 10000
keepalive 1
logging
border 10.10.10.1 key-chain key1
interface FastEthernet0/0 external
interface FastEthernet0/1 external
interface Vlan1 internal
learn
throughput
periodic-interval 1
monitor-period 2
prefixes 200
aggregation-type prefix-length 32
backoff 180 360
mode route control
mode monitor active
periodic 180
resolve delay priority 1 variance 3
resolve utilization priority 2 variance 20
active-probe echo 1111
oer border
local Loopback0
port 4444
master 10.10.10.1 key-chain key1
interface Loopback0
description OER Master Controller
ip address 10.10.10.1 255.255.255.255
ip virtual-reassembly
description ***Connection to billion modem***
bandwidth 1024
ip address xxx1 255.255.255.252
ip access-group 101 in
no ip redirects
no ip unreachables
ip nat outside
duplex auto
speed auto
crypto map SDM_CMAP_1
description ***Connection to ZTE modem***
bandwidth 1024
ip address xxx2 255.255.255.252
no ip redirects
no ip unreachables
ip nat outside
duplex auto
speed auto
crypto map SDM_CMAP_2
interface Vlan1
description ***Connection to switch***
ip address xxxx 255.255.0.0
ip access-group 100 in
ip nat inside
ip inspect SDM_LOW in
ip local policy route-map equal-access
ip route 0.0.0.0 0.0.0.0 xx1 track 123
ip route 0.0.0.0 0.0.0.0 xx2 track 345
