Cannot ping the other subnet
Jul 7th, 2008
Hello everybody, today i connect a lan with cisco 2600. conecting it to two switches, making 2 subnets, but i cannot ping to the router or to the other subnet. Could somebody help me? I'm studying to CCENT.
Richard Burts Mon, 07/07/2008 - 17:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jorge
You have not given us much to work with and some additional details would be very helpful in our efforts to understand your situation and suggest solutions for your problem.
A good place to start would be to post the configuration of the router interfaces (and even better would be to post the entire router config).
In addition it would be good if you would post the output of show ip interface brief on the router.
We would also need to know how the router is connected to both switches. What port number on each switch is connected to the router and are the ports configured as access ports or as trunk ports. Then we would need to know about the ports where the PCs are connected. Are they access ports or trunk ports? What vlan do they belong to (and what vlan does the router port belong to)?
Finally we need to know how the PCs are configured: what IP address, what netmask, and what default gateway.
If we know these things we may be in a better position to understand your problem and to suggest a solution.
Rick
ingemartinez Mon, 07/07/2008 - 18:03
Another problem is i'm trying with Network Visualizer 5.0.
This is the interface brief:
Router(config)#show ip interface brief
% Invalid input detected at '^' marker.
Router(config)#exit
Router#show ip interface brief
FastEthernet0/0 10.87.200.1 YES manual up up
FastEthernet0/1 10.87.201.1 YES manual up up
Serial0/0 10.82.15.2 YES manual up up
Serial0/1 unassigned YES unset administratively down down
In the computers in the simulator i put, as requested from it:
pc ip: 10.87.200.10
subnet: 10.87.200.0
default gateway:10.87.200.254 (ip of switch)
pc ip: 10.87.201.10
subnet: 10.87.201.0
default gateway:10.87.201.254 (ip of switch)
If something else is needed please let me know.
Thanks so much
ingemartinez Mon, 07/07/2008 - 18:07
Router Con0 is now available
Press RETURN to get started!
Router>enable
Router#show cdp neighbor
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
Router Ser 0/0 170 R 2621 Ser 0/0
switch Fas 0/12 170 SI 2950 Fas 0/1
switch Fas 0/12 170 SI 2950 Fas 0/0
Richard Burts Mon, 07/07/2008 - 18:22
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jorge
Most of the additional information that you posted is helpful. The information seems to show that the router interfaces are probably ok as configured. I would think that on the PC that the default gateway address should be the router address rather than the switch address.
The show cdp neighbor shows that the switches are 2950 which are layer 2 switches. So there is no possibility of routing login on them. We still do not know whether there is a single VLAN per switch or if there are more than one VLAN per switch. Can you clarify that?
It might also be helpful to have the subnet mask information from both router interfaces. And perhaps the output of show ip route from the router would also be helpful.
Rick
ingemartinez Mon, 07/07/2008 - 18:29
All switches are working with the default vlan:
switch#show vlan
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
The problem was just in one, routers, maybe you can ignore it, is because im testing another things rigth now. But all subnet masks are 255.255.255.0.
If you need to know something else please let me know. Thanks so much and regards.
Richard Burts Mon, 07/07/2008 - 19:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jorge
From what you have posted I can not find a reason why the PC could not ping the router interface to which it is connected, and I would like to clarify whether that is really a problem or if I just did not understand correctly your description of the problem.
There is clearly a problem with the PC attempting to ping the other router interface (the one it is not connected to) or ping the other subnet. If the PC default gateway is the switch address (.254) then the PC will send anything to a remote subnet to its default gateway (the switch address). But these switches are layer 2 only switches and can not route to any remote destination. To correct this issue you need to configure the PCs default address as the router interface on that subnet. The router does have the ability to route to remote addresses (which the switch does not have).
Rick
