Remote VPN users unable to reach OSPF Inter Area Networks
Answered Question
Jul 7th, 2008
  • Gold, 750 points or more
Hi All,
Area0 & Area1. Area1 ASA has remote VPN configuration where users uses split tunneling also. When users VPN-in, they successfully access all the respurces in Area1, but unable to reach resources in Area0.
But Area0 PCs able to 'ping' the VPN-in IPs. I tried 'debug icmp trace', but not even single message poping up while initiate the 'ping' from VPN-in users laptop.
fyi.. Area1 N/W: 10.251.0.0/16 and 10.251.40.0/24 has been used for VPN users DHCP. Everything works fine except for reachability to Area0.
Any suggestions..?
Thank you
MS
Correct Answer by a.alekseev about 8 years 10 months ago
access-list nonat extended permit ip SiteA 255.255.0.0 SiteAVPN 255.255.255.0
access-list nonat extended permit ip SiteB 255.255.0.0 SiteAVPN 255.255.255.0
Overall Rating: 5 (1 ratings)
mvsheik123 Mon, 07/07/2008 - 18:40
correction.... Area0 PCs also unable to reach VPN-in users....
thank you
MS
srue Mon, 07/07/2008 - 18:52
  • Blue, 1500 points or more
not enough information.
tell us more about your network, including routers and any other layer 3 devices.
if possible, post your firewall config.
mvsheik123 Mon, 07/07/2008 - 19:38
Please find the attached.
Area0 L3 device <-> Area251 L3 device we have a 100Meg P2P link runs OSPF. i took out the config that is not needed from the devices.
Please review and suggest.
Thank you
MS
Correct Answer
a.alekseev Tue, 07/08/2008 - 00:59
mvsheik123 Tue, 07/08/2008 - 05:13
Adding
access-list nonat extended permit ip SiteB 255.255.0.0 SiteAVPN 255.255.255.0 .. did the trick.
Thank you very much.
MS
