banner login
Jul 7th, 2008
The new banner does not have any Carriage Return,but it is a long row of characters.
I cannot find out why some Cisco 1841s, when configuring in input (copy and past) the new banner (banner login ^C), do not accept the entire banner, but they cut the last part of it.
All Cisco1841s are using the same IOS version.
a.alekseev Tue, 07/08/2008 - 05:42
  • Gold, 750 points or more
because in the config you have two delimiting characters ^ and C
in input (copy and past) - requires only one delimiting character
lcolimoro Tue, 07/08/2008 - 05:56
Nope!
I tested it as per your suggestion, but it does the same think!
Entering in "banner login" configuration mode it seems there is a limit to the input buffer per each row!
Strangely it works fine for some 1841 Router!
