WLC: Configuring Global Credentials for Access Points
Jul 7th, 2008
I have an WLC 4404 running Software Version 5.0.148.0 with 40 LWAPPs (1242AG, some 1231G). I want to configure global credentials for the LWAPPs. The configuration guide did not mention, if I have to reboot the LWAPPs after setting the credentials.
So, could I set this option during operation time? Thanks a lot for your help.
Simon
Overall Rating: 5 (1 ratings)
Scott Fella Tue, 07/08/2008 - 03:45
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If you want to create a username and password for your LAP's then enter this command:
config ap username password
jeromehenry_2 Tue, 07/08/2008 - 04:26
  • Silver, 250 points or more
Configuring the "Override global credentials" option in the GUI does not reboot the AP. It can be done in a production environment, just did it on one of my 1252s to test.
Hope it helps.
Jerome
Trending Topics - Security & Network
