Attendant Console problem - only 1 incoming line.
Answered Question
The problem I am having is there is only 1 incoming line so if the attendant console user is on a call then any incoming callers receive an enagaged tone.
We are running Attendant Console 1.4(1 ES14) on Call Manager v4.1. All attendant console features appear to be working normally.
I have setup a pilot point and associated it and the handset line number with ac user. By default there is only 1 handset and 1 attendant console user being used with the attendant console.
The phone being used with AC is a 7961 with 1 line setup.
I am aware of call queuing but that is not suitable for our environment.
I need to increase available lines to >1 and despite all my efforts I have been unable to find any way to do this.
Is this a limitation of the attendant console system or some configuration error on my part?
Do I need to put more lines on the phone and include these in the hunt group? This seems like a waste of phone lines!
Correct Answer by Rob Huffman about 8 years 10 months ago
Hi David,
You are right on the money here my friend :) You do need to add more lines to the Hunt Group and phone but don't forget these don't need to be DID lines. For example, really only the Pilot # needs to be reachable from the PSTN the other Line members can be local (Internal Only) numbers.
Say your DID range is xxx-xxx-2000 to xxx-xxx-2299, you could use the 4xxx range of numbers for Internal applications such as this.
Hope this helps!
Rob
Overall Rating: 4 (1 ratings)
tim.giles Tue, 07/08/2008 - 03:06
  • Silver, 250 points or more
Have you tried increased the max number of calls and busy triggers?
Please rate if useful....
Correct Answer
Rob Huffman Tue, 07/08/2008 - 04:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi David,
Hope this helps!
Rob
