07-08-2008 02:12 AM - edited 03-06-2019 12:03 AM
Can any one help on this, if the network consists of 2 core switches and 10+ distribution switch, is it feasible to configure the VLANs in distribution switch. Whcih is the best config to do when designing a VLAN.
Is it good to keep the VLANs under core switch or distribution switch.
07-08-2008 03:05 AM
Not knowing ur full requirement, I will give a generic response.
I usually try to seperate VLANs from access to cross to core. so, I use access vlans on access switches , then route back to core switch on over one uplink VLAN.
Sam
07-08-2008 03:15 AM
That means no vlans are entering into core switch. In that case where can we run the HSRP.
07-08-2008 03:33 AM
Are u planning in terminating ur vlans on access switches. what I have in mind is :
ACC_SW01==CUST==ACCSW02, all on same VLAN, then you can run HSRP on access switches.
Please add more info on your requirement, so we can help you better.
Sam
