default route in EIGRP
Answered Question
Jul 8th, 2008
hi ,
How can I inject this default route in EIGRP
ip route 0.0.0.0 0.0.0.0 10.0.0.254
thanx
Correct Answer by Nagendra Kumar ... about 8 years 11 months ago
"default-information" command in EIGRP will not originate a default route as like OSPF. It works a bit different.
It instructs the router to accept/advertise the default candidate network. (Hope you remember IGRP doesnt advertise 0.0.0.0 network and so we use ip default-network command)
Say you have the below tpology,
R1------------R2------
10.0.0.0 11.0.0.0
In R2, if you configure "ip default-network 11.0.0.0" command.
11.0.0.0 network will be marked as default candidate network in R1 as below,
D* 11.0.0.0/8
Now configure "no default-information in" in R1, clear the EIGRP neighbor and check the table. 11.0.0.0 will not be marked as default candidate network.
HTH,
Nagendra
Overall Rating: 5 (1 ratings)
Nagendra Kumar ... Tue, 07/08/2008 - 03:03
  • Cisco Employee,
Do you want this static route to be redistributed into your EIGRP domain?. If so, you can use the following command..
router eigrp 1
redistribute static metric 10000 1 255 10 1500
fd_case17 Tue, 07/08/2008 - 03:22
ok well
What's the command under process router eigrp
default-information
it doesn't seem to work like ospf does
Richard Burts Tue, 07/08/2008 - 03:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You are correct. In current code EIGRP does not implement the default-information-originate function. In a presentation at the Networkers conference it was stated that it is planned for EIGRP to implement this in some future release. But current code for EIGRP does not do this.
Rick
Correct Answer
Nagendra Kumar ... Tue, 07/08/2008 - 04:05
  • Cisco Employee,
10.0.0.0 11.0.0.0
D* 11.0.0.0/8
HTH,
Nagendra
